X Carve Setup
Do you have a multi-meter? You can use that to check continuity.
I do not.
Ok.
You can use grbl to test the probe. Do you know how to use the Arduino IDE serial monitor?
I do not… Sorry.
I’m assuming you have the X-controller.
There should be a wire running from the X-controller ā€œProbeā€ terminal to the socket on the Z axis carriage. There should be a wire plugged into that socket and then clipped to the mill/bit in the router.
The touch plate should have a wire that connects to ā€œGNDā€ on the X-controller.
Go into Machine Inspector - Advanced and make sure that $10 is 115 ($10=115).
Do you have that setup?
I have all wired correctly. How do I get to machine inspector? When I get to the Z Probe setup, it says no contact and will not let me click on Advanced Settings.
I don’t use Easel, so I can’t answer that question.
Do a forum search for machine inspector.
$10 does = 115
Do you know what else I could do to check the Z Probe?
There are other ways, but you don’t know how to use them. We could try something else if you want to learn something new.
One thing you could check is to open up the X-controller and make sure that all of the cables are firmly seated in their sockets. The strain relief clips will close prior to the cables being fully seated.
I did that. Seems like all wires are fully seated.
I just got going. Thank you for your help.
Thank you to the Inventables community. I believe I had two issues going. First I took apart the X-Controller and I believe I reset the stop controller when I did that and then I had a loose probe wire the second time when I unseated and rewired the probe. So to make a long story short I think reset the estop button when I rewired the unit and then I found a probe wire loose.
Thanks to all - looking forward to working with this machine!
Just FYI Larry, the Inventables Z probe socket for the carriage is two wires, both the PROBE and GND. The collet clip and touch plate both connect to a 2.1mm male connector (it’s a 2 conductor plug) and then plug into the socket. The socket is normally closed and when you connect, the conductivity of the collet/plate assembly dictates open or closed.
Thanks, Justin.
Obviously I don’t have an X-controller and I was trying to describe the functional circuit.
Glad to know how it’s actually implemented.
@JustinBusby
Just re-read this. If I’m reading this correctly, if the collet/plate assemble is not plugged in then the probe input to the X-controller is in the tripped state (A5 low). Is this correct?
Yes. My guess is Inventables chose this because in the probe sequence, it prompts you to connect the probe and they needed a trigger know that you did before proceeding.
I’ll double check when I get home but that’s what I remember when I first hooked mine up and was playing with the probe setup (the whole incorrect v1.0c was flashed on Xcontrollers from a year ago)
I would comment on that, but my comment would be flagged. H*ll I’d flag it.
