X Carve Pro Randomly Carving off Path
Is anyone else have issues with their X Carve Pro randomly cutting off path? It happens to me no matter what design software, control software I am using. I don’t use Easel for its limited capabilities. Brand new machine and it happens with or without dust collection. Newest firmware installed as well
I’m having this issue as well, but I believe my issue is due to it cutting too far over on a pass, grabbing the wood, and forcing the router head into the wood. Is it usually an aggressive diagonal cut into the wood?
I had the same issue and was able to resolve it by slowing down the feed rate to 100 in/min (carving birch plywood), ensuring the depth per pass is half the diameter of the bit (0.125 for a 0.25 inch downcut bit), and using the proper grease. I was originally using White Lithium grease by WD40 on the rails but after talking to Giovanna, she suggested trying the inventables grease and have had no problems since as long as I keep the feed rate at or below 100 in/min. Best of luck.
Are you still having this issue? I’m experiencing my xcarve pro consistently offsetting it’s x position just before 50% of the carve. In each case, I’m doing a finish carve using a ball nose. I’m using gcode from vcarve pro. It happens with both the easel and xcarve post proc. Other cnc cuts are fine, including roughing passes. I did manage to get a relief carve complete without issue using a vcarve but, not a ballnose.
I have the exact problem. Have you found a solution?
I’ve had Inventables trouble shoot with no luck.
