I’m trying to use the home position as my work home for consistency. After I use the z-probe is there a way to send the machine to the home position for the start?
What are you using to control your machine? Easel or something else?
You shouldn’t need to send it back to 0,0 before you start the program if you’ve already set your work origin.
It goes througb the startup procedure. Then use the z-probe after it asks you to set your work home position. Im trying to make it go to the home position. Basically i want to use that position as a repeatable.
If you have carved from that position since last power off it will be remembered and you can choose “use last xy position”.
Even powering off the machine won’t affect the work zero. This assumes you have homed the machine.
