Thermal expansion and contraction of parts between summer and winter
My X carve is in an unheated shed. I had the machine dialed in pretty well this Summer and just made a part out of plastic today in January. It’s about 35 degrees F and was probably below freezing overnight.
My results seems undersized compared to the drawing I just made before converting to Gcode. I will go back in and check and adjust the accuracy, but it makes sense that the aluminum would shrink some changing the tension on the belts. I’m sure all the plastic parts change a little too. I’m just curious if others have had noticed this change in their machines from season to season?
