I am trying to make the mallet that Jeremy Schmidt made but his project cannot be opened in Easel. Does anyone know how I can get it? Thank you.
which project are you trying to get. I see three when I search
https://www.inventables.com/projects/search?utf8=✓&query=+Jeremy+Schmidt&button=
If you are referring to the first link that file is a SVG and needs to be imported into easel. use the import function and size as needed.
