Perhaps more of a Inkscape question, although hopefully there are a few Inkscape pros around that can point me in the right direction. Or let me know where I can find what I’m missing.
My daughter hand wrote “Kinderfest 2016” for some wooden pins I’m making, for well a Kinderfest. And perhaps I’m doing something wrong but I’ve gotten an outline of the letters in Inkscape after scanning and path trace bitmap and object to path. The outline letters are not going to work for the size I need in Easel. I’m thinking if I can get a single line trace of the letters I can get the small size I need on the pins.
How can I get a single line trace of this scan? Or turn an outline into a single line drawling SVG?
Have you checked out F-Engrave? You could use that to generate the G-Code and import that code into Easel for cutting.
Another option would be to import the image into Inkscape on one layer. Adjust the opacity of that layer down to about 50% or so. Then create a new layer, and use the path tool to trace the lines of the letters using a stroke width of 1.
I opened @ErikJenkins Kinderfest2016.dxf in F-Engrave and saved the G-Code file.
Imported the G-Code file into Easel and received the following error: “Invalid G-Code Line 76: G91.1
The file contains invalid G-code syntax. You must use one of our official post-processors in order to import external gcode.”
Looking at the G-Code Import screen it seems Autodesk Fusion 360, MeshCAM, Vectric V-Carve, Aspire and Cut2D are the supported CAM programs.
@BradT thanks for the additional option. That worked great. between smoothing of the line and width of 1, I was able to get an actual path from the letters!
