Having trouble setting depth of cut anyone have any ideas when I set depth at .125 it changes it back to one inch
Hi Hyppy…
I will assume Easel… Your cut will only go as deep as the material depth… Change the material depth, and you will be able to adjust your cut depth…
having a problem with machine cutting much deeper than setting , I have made sure wood thickness is correct and even went less depth and it still seems to cut deeper than I wand
Hey Hyppy…
Are you using a probe? are you using a piece of paper? Going by eye? How much deeper is it going?
The more info you throw out the better the responses will be…
Would love to help… but will need more context…
Thanks
Ron
Ron I’m using the cutting depth gauge built into x-carve I set it at .025 and it going down to at least a 16th of an inch. When I set the machine up I put in wood thickness 3/8 or .375 and and youre asking about probe think I have one but never figured out how it worked . What I need is a outline more than anything deep thanks
Hi there… Suggest you read through these topics to give you some ideas of what might be causing it.
https://community.inventables.com/t/phils-help-documents-and-tutorials/29460/37
Let me know if any of these help out…
R
