Turn my machine on (x-carve pro) yesterday and the y2 step motor was not operating. Swapped cables, tested cables. Motor works, and there are no shorts in the cables.
The issue seams to be from the control board.
I’m in the middle of a project with a deadline and no help from inventables, and the website says the control board is out of stock… Has anyone had any luck contacting inventables? I only get reports that customer service takes forever, if ever, to respond with the “tickets”.
I know this is a common problem since there are a bunch of threads with no resolutions or actual help.
Some people have purchased replacement controllers from other companies, but those companies don’t carry this controller board anymore and looks like inventables doesn’t either…
Has anyone repaired there control board? Or found a plug and play replacement? Or, a board that i can wire the existing cables to that will operate with easel and the current step motors and such?
Any help is appreciated.
