I was looking at the X-Controller and like the all-in-one setup with easy connections, but now that’d I’ve done the ‘hard work’ of wiring my XC and soldering and setting it up, do I really need it? Will it give my system that much more that it can do? I just built a drawer for all my components (when adding the 3.8W laser) so can put it out of the way. No room for the X-Controller sideboard, so would have to mount under somewhere.
- I am definitely interested in a z-probe option
- I did do a basic X axis stiffening, but the wide makerslide is intriguing
Just trying to judge:
- #1 - is the cost worth the added features for the XC Upgrade Kit?
- #2 - is the time worth it with all the rewiring and setup?
#Thanks!
I think I read online that you had to reboot/reset your Arduino after doing the GRBL 1.0c update. Is that just unplug,replug? or pushing that putting on the gShield?
I just installed my A5 wire and ground and used the HexUploader (for mac) to install the GRBL1.0c hex but now can’t connect to it…
re-uploaded the grbl_10c_20161011.hex file using @paulkaplan’s HexUploader and looked to do the trick! Now recognize the machine and and did the machine setup and z-probe worked during the setup!
Thanks @PhilJohnson
(also, it now looks like you can just use Easel to update GRBL without having to use the HexUploader. next time…)
May or may not have done this a few times…
just did my first test carve with the Z-Probe… had me like:
loved it! it was SO easy and overly pleased with the results! I’m hooked on probing…
Thanks for the help on here on getting me setup!
Also, not sure if it’s a result of the wider makerslide, but I feel like my machine is a LOT quieter now!
