Working on setting up a newly built machine with the X controller, just finished setting up soft limits and everything seemed fine. I wanted to do the easel test cut and went through the machine setup to get to it. When I got to the point where you move the axis to confirm direction nothing would move…
I backed out and went to Carve to try and move them manually and only Z would work.
I turned off soft limits, and now it seems like I can jog all axis but I can not home? It will home Z and then when it gets to XY it gives me an error and says to make sure the axis aren’t blocked.
i’m afraid its possible that when I was in the machine setup I picked arduino instead of X controller since I had arduino on the last machine.
Ideas?
