So I just ordered a fully loaded 1000mm kit and can’t find which bits ship with it.
I’d also like to know what a basic starter pack of bits should contain. I’m not doing any PCB stuff. Just wood, mostly engraving and some inlay work. Might have a go at milling Aluminium at some point.
These will help you get carving with your X-Carve!
X-Carve Clamp Set - [Add $35.00]
Secure material to the waste board while carving
High Speed Steel 2 Flute Upcut Spiral - [Add $9.90]
Onsrud bit with 1/4" shank and cutting diameter, good for woods and soft metals
Solid Carbide 2 Flute Spiral Upcut (Ball Nose End) - [Add $42.00]
Onsrud bit with 1/4" shank and 1/8" cutting diameter, good for more detailed work in plastics, woods and soft metals
