Waste board worpage
Any one have issue with the waste board being worked on the 1000mm I just got this.
Hello Kent and welcome to the forum,
From what I have seen over the past 2 1/2 years is that a lot of the waste boards warp, its MDF and it doesn’t stay flat. Secure it down to the frame and add a 1/2" piece of MDF to the top and take a skim cut so you have a flat surface to work with. Some people add T-Tracks or you can cut the holes in the MDF so you will have access to the threaded inserts in your waste board.
Russell
I shimmed my low spots between the base frame and the waste board using card stock.
