This may be an Easel question, but does Inventables have a Touchscreen capable PC controller that they recommend ? Has anyone used a Apple iPad or other Tablet type PC to work with the X-Carve Pro?
Good morning RiverEdge,
I use a Microsoft Surface Pro 6 to run my X-Carve setup. It worked well with both Easel and the Vectric VCarve Pro I now use. I just had to change the power management settings so that the screen did not timeout when plugged in. If the tablet goes to sleep, the program stops.
Doug Pauls
Thanks Doug
Appreciate the response - we were looking at the MS Surface, so think we will give it a try.
