Subwoofer rounded corners
Hopefully this is the correct sub for this question.
looking to build a subwoofer box for my truck and want to do rounded corners as my last truck I simply made a wedged box and corners were annoying at times. Found that car audio fabrications has templates to use on a table router but figured since I have an xcarve, I’d just use that. However, I can’t figure out how to create the shape in easel. Tried combining half circles with rectangles to create the 3/4” offset, pen tool and combination of those. Can’t figure it out lol.
Any input or suggestions would greatly be appreciated.
This is what I am trying to do.
Probably the easiest way to get a curved slice like that is to start with a rectangle with rounded corners, subtract a smaller rectangle from that (you’ll have to do some math for the right dimensions), then subtract away two of the sides.
I quickly mocked it up here. It’s 4 steps from the top-left. The second step is the 2 top left shapes combined and the final shape is the 3 bottom left shapes combined.
Take a look at these…I have recreated the 3” - 8” templates. My suggestion, you can either create 1 of each as a template and do as the video showed, or just plot all those you need onto a surface and let Easel cut them all for you and then stack them using .25” dowel pins/
Thank you! I was at it for hours, complicating it every step of the way lol. I eventually got something close by doing something similar to what you mentioned. Thank you so much for the input!
That’s great!!! Thank you so much!
This topic was automatically closed 180 days after the last reply. New replies are no longer allowed.
