I am about to order m X-Carve. I would like to know either the DeWalt or Bosch adapters will work withe the (currently owned) Rigid palm router? Thanx in advance for your help.
If you have a Ridgid 2401, none of the Inventables mounts will work due to the raised area on the router body that the height adjustment jack screw runs though. If you have the older 2400, one of the mounts might work, but you’d need to measure the diameter of the router body and see if it’s close enough to do the trick.
I do have the older router, I will measure it this evening.
The diameter of the router is 2 7/32".
