Replacement Router
I have the X-Carve 1000 that came with the Dewalt DW611 router, I’ve replaced it once with the same model and now I need to replace it again. However the DW611 is nowhere in stock. What other routers will fit my X-Carve and that you recommend?
Thanks.
Are you sure you actually need a new router? The brushes on the motor wear out after prolonged use and are very inexpensive / easy to replace. There are some other threads on this forum about it or just google “replace brushes DW611”.
I will give that a try, thank you Tony for that info.
I have the Brushes on order, hope to get them by the end of the week. Thanks again.
Hope this fixes your problem. If so, I would suggest keeping a couple spare sets of brushes on hand.
Up and running, thank you again for the recommendation. I am now logging my hours of use on the brushes. Do you happen to know the average # of hours the brushes should last?
Thanks,
David
Put an old sock over the air intake on the router…your brushes will last much longer.
Do you think the dust from carving reduces brush life?
Yes. You can’t put anything that will impede air flow, but a dinner is a good idea.
Most seem to report 150-200hrs if kept at speed 1.
Some less, some longer.
