After login to Easel, cabinetmaker opens and I have click “switch to easel” link. Is there any option to remove cabinetmaker from my account or set Easel Pro default after login?
Hey Marek,
Is this happening every time you login to Easel? If it loads Cabinetmaker, and you switch to Easel, Easel should load the next time that you login because it was the most recently used application.
The same thing is happening to me. And I do log into Easel and log out, BUT the same thing continues to happen when I log back in….it always goes to Cabinet Maker an I have to to the menus to get to Easel Pro. ITIS A PAIN TO HAVE TO DO THAT EVERY TIME. I HAVE NO DESIRE AT THIS TIME TO BE IN THE CABINET AREA!!!
Yeah, this is happening to me, too. I haven’t used cabinet maker in a while but it seems like every time I get logged out and log back in, it starts in cabinet maker.
It’s a minor annoyance, but I’d rather have one of the following happen:
- Before logging in (i.e., while entering my password), let me select which service I want to use. This could either be a dropdown, or it could be two buttons (
Continue to Easel•Continue to Cabinet Maker). - If I have access or used both services, prompt me after logging in which I want to use, rather than making a guess.
Honestly, even when I was using both services, it was more often than not taking me to the wrong one, which is confusing and takes several clicks to switch services. Asking up front is more useful unless I have deep-linked directly to a specific project.
