Parts being cut in the wrong place
I am trying to cut cabinet parts in a 4x4 sheet of plywood. The parts in the front right quadrant are being cut on top of each other. The problem happened trying to cut both from cabinet maker and after exporting to Easel. As far as I can tell, everything is square and the belts are tight. I updated the firmware. Running out of ideas and after losing a sheet of plywood I am reluctant to try again.
