I’ve noticed that small holes are oval instead of circular. I have done x y step calibration. It’s accurate to the mm over a distance of 500mm
I have also had issues with a random deviation of a cut path. It will randomly jet out of position. And gouge the material but then continue back on its course. Usually back in the right position.
Phil, thank you so much for helping me with this. I didn’t put together the machine, and now I’m worried now that there are no set screws - i found 5 instances like this on my machine - are set screws meant to be here?
