New machine setup Homing Failed
I am at the last step in the setup of new xcarve pro 4x4. Jogging machine in all directions (X,Y, and Z) work fine. When I start the homing process the Z goes up and then stops. Nothing happens – X and Y do not move. Checked all connections and everything looks good.
If I go to Easel/Machine Inspector and manually press each limit switch, they each light up green.
