Hello! Ive been reading tons of forums and can’t seem to find the solution to my problem. Hoping to find some help from the community. Thanks in advance.
I am using a 3018 CNC with easle. When I go to start carving I work through the bit size, material thickness and position settings. When I put the bit in the correct position I click on “Raise the bit”. At this point instead of raising up just enough to move around the material it goes all the way up. I then click “turn spindle on” and then Carve just to see what happened. It follows the path but does so a few inches above the material. No matter how many times I reset the position, reconnect the machine, I still have the same problem. Ive looked at the machine inspector settings and… well lets just say I’m not to familiar with computer lingo.
Hey there. Thanks for the reply. The setting you mentioned is set to 800. Attached is a screen shot from the machine inspector. Easel - Milwaukee Cut out.pdf (171.9 KB)
Setting the Z probe to zero meaning I find the bottom left corner of the material and bring the probe just right above the material. Close enough for paper to slide in. This is the point when I hit raise the bit and it just goes all the way up.
I appreciate the help, I really do! After putting that code into the console it jogged the machine to the right spot but still did not carve the board like I wanted it to. I took a video if that helps, but is too large to upload here.
Also, I did two test runs earlier with some random text and it worked just fine…
Yes it was done in easel, I just typed some random text and sized it to the material and depth. If you had an email or someplace I could share the video that might clarify the issue.
