It’s here, let the fun begin. Maybe the x-controller will be available before I am done.
On the y plates the instructions say bolt v wheel washer eccentric nut, this was not the case on the x careage it was bolt washer then v wheel. Are the v wheels on the bottom of the y plates supposed to get tight?
the bottom 2 vwheels have the the bolt coming from the inside face of the machine so you first put the vwheel in the bolt, then a washer and on the other side of the plate you put the excentric.
Lucky you I’m still in the dreaming of one phase.
