hey this is michael from denmark i have a litle problem with my laser for my x carve i had purchased. My universal g code sender says error while starting file stream :0. i can not get it to run can anyone help mee?
What version of grbl do you have installed?
version v2.0.0
Thatโs the UGCS version number. Iโm trying to find out the version number of grbl you have installed.
were can i find that
When you start the UGCS session by clicking on โOpenโ grbl will output an introduction message. That message should contain the version number.
Post the version number here.
Also, in the command line enter the command $$
post the results of that output here as well.
grbl 1.1
command line: $:30=255
$31=0
$32=1
Try entering the commands manually into the Command line box at the bottom of the screen.
To turn the laser on This would be very low power, wear your eye protection anyway.
M3 S10
G1 X0.001 F5
To turn it off
M5
i can turn the laser on using G1 F4000 M03 S10 on low power
and M05 to turn i off
your codes does not work
now i can load a g code file and machine starts but the laser wont fire ?
Since you are running grbl version 1.1f it plays by different rules.
hey again i have now got the laser to engrave but the x carve seems to be running to fast for the laser to ingrave. Im using aspire to make the gcodes and i have downloaded the gcode sender from jtech GRBL โ Dynamic Laser Mode M4 & No Z (X Carve, Shapeoko 3, etc.) is this right ?her are som pictures
