IOT Relay Issue
Greetings - just picked up a used x-carve and wanted to use an IOT relay. I have installed it and it works… for about 3 sec and then turns off.
I have tried both wiring ports on back of x controller and they both do the same thing.
The ‘always on’ plugs works fine to manually turn the router (dewalt 611) off and on. As such, it seems like the relay is working appropriately.
In searching the posts on here, some folks had similar issues but no clear resolutions.
Thanks in advance for any help!
