How do you get letters to cut out can’t find an app for it
Enter desired text in Easel, set carve to Outline and either outside path/on path or inside path.
Inkscape. Create a text box, change object to path, save as SVG, import into Easel.
Both are correct.
If the font you like is already in Easel that is a very easy way to get them done.
If the font you like is not in Easel but you have the font installed on your system then Inkscape is a wonderful way to import your text into easel.  you can then use the Exploder app as needed as well.
