I did my first cut and used the REINDEER project listed.
I used all the settings that the software suggested and
used the 1/8 inch bit that came with my x carve upgrade.
The project was running pretty good ( I could use some fine tuning
on the belt tightening and some squaring up on X,Y and Z).
The biggest problem I had was by the time it was almost done the
router bit was burning out and stop cutting that cause motor skipping.
Is this a problem with feed rate and speed or the bit itself.
I believe that the Inventables bits are HSS and not
carbide.
Any thoughts or suggestions?
Thanks for all in the forum for all your help as I work through
the beginning stages of X Carve ownership.
Greg
