Hi - I’m new. I just put together my machine over here in Merída, MX and everything is mechanically sound.
I have a newer model with a Z-Probe and homing switches. I installed the Easel driver “.3.10” on my computer (OSX El Crapton or whatever they’re calling it now, the latest one).
I guess this is kind of a multi-issue thread so I’ll try to go through the process -
After OSX driver was installed, I continued along the Easel machine setup process. Everything went fine with connecting, but the motors were all responding inversely - I am 1000% certain my wiring is correct (I can recite the pattern from my head for the motors, left to right - X = R,W,G,B > Y1= R,W,G,B > Y2 = R,W,B,G > Z = R,W,G,B). So I let the software redefine it automatically.
Went through the homing process fine, then the Z-Probe process was a little strange. It connected up but the actual setup process is weird…when you touch the plate to the tip to check the circuit closes and allow you to continue, nothing happens when you hit continue. It just takes you on to the next step. So I restarted the process and then went to the Advanced section before continuing, and it allowed me to do a test probe there. That worked, but does that actually set your machine? I don’t get it…
Anyway, I went onward, my machine home location displays as -798,-798,-6 or something like that (instead of 0,0,0 ?). I assumed this was from having to reverse the motor directions, so I leave it and go to do a test carve with everything setup correctly.
The router bit’s home position is lower than my material, but I assumed it’d raise itself up before beginning…I was wrong. It just swung over and took a bite and knocked a clamp off before I hit the red button on top of the X-Controller.
NOW, I am trying to re-connect to the thing and it just hangs saying “insert USB and turn on machine” when it’s already connected and running. I am really annoyed about this, I’ve tried turning off and on, re-installing driver, etc. Nothing is bringing it back.
I should note that before doing the carve, Easel brought me into a new window to double check my settings were correct…and then asked me again if I wanted to do my z-probing, so I selected manual because I was confused…anyway, what am I supposed to be doing here. I’m sure my understanding of the z-probing process is the cause of the issue here, but I really can’t get the thing connected again.
There was also a message about there being new firmware for the machine that disappeared when I pressed carve. I can’t find that again, or where to do it. I think I need some directions here…
