Emergency stop didn't work
Just had a troubling thing happen. I messed up my programming and set to cut.4 instead of .04.
spindle came to a dead stop. I hit the emergency stop button on the box and it did nothing. XY movement continued. I had to use the stop in Easel. I’ve used the button before and it has worked. It had connectivity because the Led was lit, and I had just used it to probe. Fixed the program and went on to carve just fine.
Anyone else have this issue? I shouldn’t even be able to control the router at all with the e-stop depressed, but I was.
