Copy image help
I want to cut out multiple pieces of same design on a single board. in this case leaves… is there a way to copy and paste the leaves over and over again without having to import the image from clip art over and over again? please help as importing over and over again is my own personal hell
Select the design then go to edit>copy. Then edit>paste.
Or use the hot keys ctrl+c and ctrl+v
Or select the design then the lego button on the left and use the replicator app.
