Canvas Size
Hi, Is it possible to import a 48" X 48" size svg in EASEL to generate GCODE? If I shrink the size of the canvas , will it shrink the size of the each object as I have 36 objects on the svg ? Thnx
You can change the grid to a 48x48 and work from there.
Just remember that the machine will try to carve it even if it is outside your work area unless you set it to zero depth.
