How I can to calibrate X carve belts??
You can adjust tension on the belts by tightening them. Calibration is a word used to change the steps per millimeter of the motors to get more accurate results when moving the axes. Some folks have used a fish scale to get the same tension on the belts. I just have adjusted them so they pull up an inch or so and sound the same when plucked.
