I actually broke my first bit because I had dewalt set to a 6 and was going too slow, the bit got so hot it snapped. When I slowed down my rpm I found I could actually speed up my cuts to increase the chip size which keeps the bit cool.
i made some circles (thoses who fail yesterday)
1000mm/min doc 1mm speed 1 : ok
1000mm/min doc 2mm speed 1 : FAIL
1500mm/min doc 1mm speed 1 : ok
2000mm/min doc 1mm speed 1 : ok (seem the limit) and there is some burning spot when the bit raise up to make the tabs
it’s funny to discover that you can increase the speed but not the deep ^^
edit:
weel no at 2000mm/min it fail at the second time
well… you were right
after 30min of adjustment of potentiometers
watchout about limit switch, i was close to destruction
I could well increase the power in my axes
I did some test with the 1/4 bit inventable provided during the purchase of x-carve in my and my board seems to be OSB I tested
1000mm / min @ 2doc => ok
1500mm / min @ 2doc => ok
2000mm / min @ 2doc => ok (and easy !)
1000mm / min @ 3doc => ok
1500mm / min @ 3doc => ok (littles suspects sounds)
all this are in full cut (no stepover)
(not sure how to say in english… well 1/4 bit for 1/4 wide cut…)
thanks all for your recomendation !!!
i will check later for the 8mm bit… (seem badly burned XD)
