Everything went sort of OK, except the box cuts where not aligned nor sized properly. I see that the app states something about dog-bones that I did not follow. Maybe this is related.
Any help appreciated! Look at the photos for the issues. As you can see the edges of the cutouts don’t line up
@PhilJohnson - didn’t you have a post describing how you zeroed in on making better (almost unnoticeable) dog bones? I can’t find it. Or do you use a specific formula?
It is working on me perfectly. By changing circle locations, you’re cheating on dog bone created lines. Kind of re-drawing manually.
Same as VCarve. Dog bone size must be half of the diameter of the bit you’re using. Also inputting exact material thickness critical.
You’re the one talking about editing dog bones.as you posted.
I’m saying you do not need to change anything on easel dog bone creator.
Simply create box on easel applications , click on Dog Bone creator app, change notch size to half of the diameter of the bit you’re using. Done.
Picture follows.
Just for grins, I sent @PhilJohnson’s graphic to Vectric to see if they can add an option for this type of fillet to vastly improve V-Carve’s joinery capability. Will respond here if I get a response.
Thanks for the simplified instructions. Two questions:
I still don’t get what the dog bone will do, since I am routing on the outside of the line, I don’t see how that will get drilled.
Easel draws an error in the preview (red lines) showing that Easel can’t drill those diameters. Makes sense since I am making the notch half the size the bit.
Maybe I should tick the outside/inside option in DogBone creator app?
