Is there a way in Easel to denote which bit to cut a section of your design with a particular bit? For example, I might want to do a through cut in a two pass carve with the bigger bit. I am making a few plaques and would want to cut the outer shape with the 1/8" bit and leave tabs for final cutout and then do my second cut with a 1/16" or 1/32" bit.
Is there an easy way to find zero depth shapes at a later time? I find myself clicking all over to find them.
You may move all of your design to negative X, the light blue background make zero-depth objects appear more easily.
You just need to set work-zero at lower RIGHT side of work piece
All good work flows, I mainly go by Master->Copy
