Howdy,
When i bought my X-Carve last year i also picked up a few of Inventables el-cheap-o $9 1/4 end mills (https://www.inventables.com/technologies/high-speed-steel-2-flute-upcut-spiral). I used one for my first test cuts then moved on to better bits…
However, Now I need to cut a simple ‘notch’ in some aluminum tooling plate (ATP5) but I have broken all my ‘nice/spiffy’ bits I’ve used with aluminum in the past.
So here i am… looking at my box of bits wondering if these ‘cheap’ bits will cut my aluminum plate? i just need a 1/4" bit to put a small 1/2" notch 4" long on the side of 1/4" cast aluminum.
Sure, i could order a new bit but im impatient and don’t want to wait for it to arive!!
Should i risk it?
