Adding tabs to picture
I picked a picture out of the Easel collection and want to add tabs to secure the thru cut. Is that possible. When you select the pic in Easel it doesn’t give you that option.
It did for me. This is from the pro library ( apple). I slid the cut down to the bottom of the thickness of material and the tab window appeared.
Thank you!
I often do through cuts on my 4040 machine and elect to not use tabs. Easel seems to remember this from the last job, and the ‘Use Tabs’ option is turned off. You can always toggle it back on by clicking the checkbox.
