Either I am stupid and round shouldered or it is very arcane trying to add a bit into the bit list.
Trying about 6 times to enter a 1/2 inch bowl bit into my selection list and the flaming program won’t let me do it.
Needs work Inventables.
I just lied for a bowl bit. I believe I configured it as a flat-bottom surfacing bit.
Then I just manually did the configuration for where to run it after cutting most of the material away with the normal bit. The bowl bit I ran on a separate workpiece but with the same X/Y coordinates.
Thanks, am trying to put it in as a ball nose bit which is a category that is listed I can remember getting frustrated two years ago, gave up when I had most of the few bits that I use entered, now have forgotten how I did it and find it over complicated.
