I have an 1000mm x 1000mm X-Carve with Upgrades and Laser that I am looking to sell. I love the machine, but I have no time with 3 kids to use as much as I once did. Including the specs below from what was originally purchased. Includes everything but the PC. I am located in Southern Maine.
X-Carve 1000mm CNC
- Rail Kit Black MakerSlide: Robust support extrusions, brackets, and hardware ensure a stable and precise carving experience.
- DeWalt 611 Spindle and Mount: Comes with a powerful 110V DeWalt 611 spindle, mount, hardware, and collet adapter, compatible with both 1/8" and 1/4" carving bits.
- X-Controller Kit: High-power motion controller for seamless operation.
- NEMA 23 Motor Kit: Four 140oz-in stepper motors with connectorized cable assemblies for smooth and accurate movements.
- 1000mm Waste Board Kit: Equipped with threaded inserts and hardware, providing a solid base for your projects.
- 1000mm Drag Chain Kit: Drag chain, mounting brackets, and hardware for efficient cable management.
- 1000mm Homing Switch Kit: Homing switches, assembled cables, and hardware for precise starting points.
- Z-Probe Kit: Ensures accurate Z-axis measurements.
- Dust Control System: 1000mm dust control system to keep your workspace clean.
- Clamp Set: 60-piece set for securing material up to 1.75" thick to the waste board while carving.
- End Mill Starter Set: 8 general-purpose starter bits with 1/8" shanks for versatile carving options.
X-Carve Upgrade Kit (Installed in 2024)
- 9mm Belt and Motor Kit: Includes a 9mm belt, three upgraded motors, 9mm idlers, belt clips, and sleeves for enhanced performance.
- Direct Drive Z-Axis with Upgrade Motor: Provides more accurate and efficient Z-axis movement.
- 2" Risers and Stiffeners: Increases the machine’s rigidity and stability.
- Additional Upgrades: Includes 9mm belts, upgraded motors (X & Y), 9mm idlers, belt clips, and sleeves.
OptLasers Addon (Installed in 2025)
- LaserDock Pro: Laser to CNC magnetic docking station for easy attachment and detachment.
- PLH3D-XT8 Hyper Performance Plug&Play 45W Laser Kit: High-performance laser kit for detailed and intricate engravings.
- Compressor Laser Air Assist: Enhances laser cutting quality and precision.
- Working Table: 4’ x 8’ working table with drawers for ample workspace and storage.
This X-Carve CNC machine was purchased in 2017 and has been meticulously maintained. The upgrade kit was installed in 2024, and the OptLasers addon was added in 2025.
Price: $3000 for everything, open to reasonable offers
