You can’t just use capacitors, look at this thread, there is also a link to the filter circuit if you would like to build it yourself. Whoever told you to use only .47uf capacitors without adding a resistor to the circuit was greatly mistaken and you can do damage to your boards. If it’s a soldering issue this board will work for you as well for all your connections. but being that you seem to know how to solder a circuit, take a look at the circuit and if comfortable you can make your own and save a few bucks from buying one. But in my opinion upgrading to a X-controller will not fix your issue as it uses the same electronics just a few upgraded chips and frills in a proprietary board.
Hope this helps,
Brian
