What is the Bottom of the Z
I am installing the X-Carve Upgrade: Z Axis Kit. What is considered the bottom of Z?
The directions says the following:
“For short bits or thin work, mount the Z a little below the bottom of the X-Carriage. For longer bits or thick workpieces, mount the bottom of the Z flush with the bottom of the X-Carriage.”
Duane
well, if you use small cutter more often then set it with option #1
I set mine flush with bottom and use a 1/2" secondary waste board when I plan to use smaller cutters.
Thanks Ken. Makes sense now.
Thank you, Seth!! Great video. I pretty much ignored that statement but was glad to see that I was right to do so. :grinning: :+1:
Duane
