V-Carve issues
I’ve been having this trouble for a bit, and I’m hoping someone can help point me where I might figure it out. When each letter is done, it leaves little scraps attached in the letters. Any ideas?
It’s not in the bottom, It’s on the angled edges. I tried uploading a photo however, It’s not letting me.
Can you try another photo maybe using the snipping tool?
It’s working for me. Are you still having the problem?
Can you tell us the bits you are using?
Like manufacture etc.
Also if you have fuzzy edges those can be cleaned up using a down cut bit that comes close to the edge to cut those or do what some here have suggested is use a Vbit that skims the edges. You will have to experiment.
The other thing is you can use a diamond coated bit to run around the edges.
Depends on what the issue is and a picture is worth 1000 words.
You can also post the image online and link it here with a web url.
pictures, pictures, pictures…are worth a 1000 words :smile:
Below is a sample of what’s happening. I’m using a “Amana Tool RC-45711 In-Tech Insert Carbide V Groove 90 Deg x 11/16 D x 21/64 CH x 1/4 Inch SHK Router Bit”
I’m not sure the font. Let me look when I get back to the shop.
What settings should be added to easel when adding this bit??
Amana Tool RC-45711
Cutting Diameter
Angle
11/16" cutting diameter
90 degree
