# Unexpected tool paths while running GCODE generated by Fusion 360
**URL:** <https://community.inventables.com/t/unexpected-tool-paths-while-running-gcode-generated-by-fusion-360/132447>\
**Category:** Troubleshooting\
**Created:** [May 24, 2022, 6:31pm UTC](https://community.inventables.com/t/unexpected-tool-paths-while-running-gcode-generated-by-fusion-360/132447 "2022-05-24T18:31:49Z")\
**Posts on this page:** 1\
**Showing post:** 8
<div class="post-metadata">
**Author:** ![ZacharyZ](https://avatars.discourse-cdn.com/v4/letter/z/9fc348/32.png) [@ZacharyZ](https://community.inventables.com/u/ZacharyZ)\
**Post date:** [July 28, 2022, 5:43pm UTC](https://community.inventables.com/t/unexpected-tool-paths-while-running-gcode-generated-by-fusion-360/132447/8 "2022-07-28T17:43:33Z")
</div>
Hi @JaredMckie: I want to be clear that the problem is corrected with the system I’m currently using.
I did not isolate the root cause, but when I have time I plan to switch back to the Ubuntu mini-computer to see if the problem comes back.
I have completely stopped using Easel to control my machine. I use Universal GCode Sender (64bit) now, and haven’t seen the unexpected tool paths since switching.
Eliminating the browser from the equation is a quality of life improvement. It is much more like operating a HAAS or Fanuc machine controller and operator interface.
I outlined the setup in [this post](https://community.inventables.com/t/x-carve-pro-losing-place/133148/5), so I won’t repeat here. If you have issues transitioning, put up a post about it. This forum is overdue for a dedicated troubleshooting guide.
_[View the full topic](https://community.inventables.com/t/unexpected-tool-paths-while-running-gcode-generated-by-fusion-360/132447)._
