# UGS gcode file size limits?
**URL:** <https://community.inventables.com/t/ugs-gcode-file-size-limits/35984>\
**Category:** X-Carve\
**Created:** [April 1, 2017, 7:09pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984 "2017-04-01T19:09:04Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![GregBuckwalter](https://avatars.discourse-cdn.com/v4/letter/g/f05b48/32.png) [@GregBuckwalter](https://community.inventables.com/u/GregBuckwalter)\
**Post date:** [April 1, 2017, 7:09pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/1 "2017-04-01T19:09:04Z")
</div>
Is there a file size limit to UGC? I generated my gcode from Vcarve Pro, 11mg file. CNC worked fine then went wonky moving supper slow, freezing, I rebooted my PC tried again and had the same issue at a different point of the file. Third time, within 2 min it froze. I had a crazy idea that perhaps the file is too big. So I cut the file by putting different cuts into 2 files, 5mg and 6mg. They both run great,
Which leads me to my question: Is there a file limit for UGS? Memory issue on my PC?
Appreciate any insight.
**Post date:** [April 1, 2017, 7:44pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/3 "2017-04-01T19:44:03Z")
</div>
What are you using beside UGCS?
**Post date:** [April 1, 2017, 7:46pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/4 "2017-04-01T19:46:26Z")
</div>
I’m using UGCS 1.0.9
**Author:** ![JustinBusby](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/justinbusby/32/30906_2.png) [@JustinBusby](https://community.inventables.com/u/JustinBusby)\
**Post date:** [April 1, 2017, 8:25pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/5 "2017-04-01T20:25:04Z")
</div>
The nightly build has better memory management from what I’ve read and experienced.
**Post date:** [April 1, 2017, 9:16pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/7 "2017-04-01T21:16:25Z")
</div>
Thank you Justin and Robert. I’d rather make a bigger files and let the sucker run.
**Post date:** [April 2, 2017, 12:45pm UTC](https://community.inventables.com/t/ugs-gcode-file-size-limits/35984/9 "2017-04-02T12:45:28Z")
</div>
Phil, What do you mean ‘Soft limits’. It froze up on me again last night during one of the files that worked two times yesterday.
