# UGS error "Multiple points" and "for input string "-""
**URL:** <https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149>\
**Category:** Troubleshooting\
**Created:** [April 5, 2017, 1:29am UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149 "2017-04-05T01:29:37Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![StephenCook](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/stephencook/32/73911_2.png) [@StephenCook](https://community.inventables.com/u/StephenCook)\
**Post date:** [April 5, 2017, 1:29am UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/1 "2017-04-05T01:29:37Z")
</div>
I do not know why I have to reset UGS when I run a file then try to load up my other file for running it throws these two types of errors and I can’t find anything on google that suggests what I am doing wrong.
Any clues?
**Post date:** [April 10, 2017, 5:00am UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/2 "2017-04-10T05:00:21Z")
</div>
Found the problem.
In the g-code it has a space between the - and the number.
example: G91 G0 Y- 15.875
There should be no spaces there.
this is the correct code: G91 G0 Y-15.875
I calculated this using Charley’s spreadsheet.
I then copied and pasted it into a text file.
For some reason it has a space but if you look for it and remove it then it works without this error.
**Author:** ![JoeMartin](https://avatars.discourse-cdn.com/v4/letter/j/d26b3c/32.png) [@JoeMartin](https://community.inventables.com/u/JoeMartin)\
**Post date:** [April 10, 2017, 5:25am UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/3 "2017-04-10T05:25:25Z")
</div>
Is this one of those cases “You get what you paid for”?
It seems there is a lot of problems lately with UGS’ builds but it is free.
Not sure if free is worth the headache.
**Post date:** [April 10, 2017, 2:59pm UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/6 "2017-04-10T14:59:17Z")
</div>
> [@JoeMartin](#):
The problem was not UGS
It was the gcode.
**Post date:** [April 10, 2017, 3:07pm UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/8 "2017-04-10T15:07:20Z")
</div>
I still need more work for this machine to work right.
I have those TB660 modules hooked up to the Arduino like you have in your diagrams.
I just need to get it rewired with some shielded wires and make a proto board so everything is tight and solid connections.
I need a better controller. I want to move away from the arduino and get something that is common and not too difficult to use.
**Post date:** [April 10, 2017, 4:26pm UTC](https://community.inventables.com/t/ugs-error-multiple-points-and-for-input-string/36149/10 "2017-04-10T16:26:14Z")
</div>
> [@PhilJohnson](#):
> proto board (with noise filter)
Where do you get the noise filter?
