Smart Measure Pro STHT77366
Smart Measure Pro is the 2nd set of Smart Tools collection (distance, height, width, area).
This range-finder(telemeter) measures the Distance, Height, Width and Area of a target with your phone by trigonometry.
Are you ready to measure? Just stand up and press the shutter. The important point is aiming the camera at the GROUND, NOT the object. (i.e. In order to measure the distance from someone, aim at his shoes.)
If it is inaccurate, please read the instructions in this app or see the checklist diagram in the blog. The sensors on your phone can be changed according to OS version, firmware and battery status.
You can calibrate them with the calibrate menu and settings for yourself.
The STANLEY Smart Measure Pro is a tool and app that immediately provides accurate measurements of areas photographed in images taken on mobile devices. The time saving tool instantly provides correct dimensions and accurate estimations of how much material will be needed to complete a project.
File Export capability-PDF, JPG, DXP
Extended range 450 ft
Bluetooth connectivity with dedicated app
IOS and Android connectivity
I couldn’t find any mention of the resolution of this thing apart from the previously mentioned minimum distance of 6’.
Sounds like something you’d want to mention in your advertising literature.
Wow. If you take a look at the distances between different points on that building without considering the displayed measurements it appears to be a very silly garage.
