# Spindle mount movment question
**URL:** <https://community.inventables.com/t/spindle-mount-movment-question/16952>\
**Category:** Troubleshooting\
**Created:** [December 6, 2015, 5:34pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952 "2015-12-06T17:34:38Z")\
**Posts on this page:** 9\
**Page:** 1
<div class="post-metadata">
**Author:** ![LachlanRoss](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/lachlanross/32/43067_2.png) [@LachlanRoss](https://community.inventables.com/u/LachlanRoss)\
**Post date:** [December 6, 2015, 5:34pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/1 "2015-12-06T17:34:38Z")
</div>
should the spindle mount have movement on the Z axis, sideways forward and backward? have adjusted the eccentric nuts but they make no difference, it freely moves around 2mm side to side and forward
**Author:** ![AllenMassey](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/allenmassey/32/84441_2.png) [@AllenMassey](https://community.inventables.com/u/AllenMassey)\
**Post date:** [December 6, 2015, 5:45pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/2 "2015-12-06T17:45:25Z")
</div>
The spindle mount should not have any side to side or forward wiggle.
Are the vwheels on the z axis all so tight that it is difficult to turn them by hand?
**Post date:** [December 6, 2015, 5:53pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/3 "2015-12-06T17:53:45Z")
</div>
top vwheels are tightish no movement of the spindle mount there but the bottom vwheels very very loose that’s where all the movement is coming from
**Post date:** [December 6, 2015, 5:57pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/4 "2015-12-06T17:57:42Z")
</div>
The bottom wheels should have eccentric nuts on them that will allow you to tighten the vwheels until there is no movement. Be sure you used the eccentric nuts.
**Post date:** [December 6, 2015, 6:01pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/5 "2015-12-06T18:01:16Z")
</div>
yeah have just readjusted the eccentric nuts again, must of come loose all seems good again. cheers
**Post date:** [December 6, 2015, 6:07pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/6 "2015-12-06T18:07:46Z")
</div>
I highly recommend you apply some blue Loctite to all the nuts on the machine. Otherwise they will all continue to loosen at the worst possible times.
**Author:** ![Bill](https://avatars.discourse-cdn.com/v4/letter/b/ac91a4/32.png) [@Bill](https://community.inventables.com/u/Bill)\
**Post date:** [December 6, 2015, 6:19pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/7 "2015-12-06T18:19:11Z")
</div>
If you haven’t used Loctite before, I’d recommend that you use the Blue (Loctite 242) as it allows you to remove the nut in the future with normal hand tools.
**Author:** ![BillJutz](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/billjutz/32/67318_2.png) [@BillJutz](https://community.inventables.com/u/BillJutz)\
**Post date:** [December 7, 2015, 4:24pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/8 "2015-12-07T16:24:12Z")
</div>
There is another thread with a similar issue that might help:
Continuing the discussion from [Should V-wheels have side to side play in the bearing?](https://community.inventables.com/t/should-v-wheels-have-side-to-side-play-in-the-bearing/11237/42):
**Author:** ![KennyByrom](https://avatars.discourse-cdn.com/v4/letter/k/c37758/32.png) [@KennyByrom](https://community.inventables.com/u/KennyByrom)\
**Post date:** [February 7, 2021, 8:39pm UTC](https://community.inventables.com/t/spindle-mount-movment-question/16952/9 "2021-02-07T20:39:03Z")
</div>
I read your reply that the spindle mount should not have any side to side or forward/backwards wiggle. I have a question as to why my spindle mount is loose. There is movement from side to side, and forward to back., The spindle wheels are tight? After tightening all four spindle wheels the spindle mount still has movement. I’m at a loss. Don’t know what to do from here Any suggestions?
