# \[solved\] X-carve stopped working after Easel upgrade
**URL:** https://community.inventables.com/t/solved-x-carve-stopped-working-after-easel-upgrade/38538
**Category:** Troubleshooting
**Created:** [June 6, 2017, 8:05pm UTC](https://community.inventables.com/t/solved-x-carve-stopped-working-after-easel-upgrade/38538 "2017-06-06T20:05:10Z")
**Posts on this page:** 1
**Showing post:** 22
<div class="post-metadata">
### Author: ![LarryM](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/larrym/32/51450_2.png) [@LarryM](https://community.inventables.com/u/LarryM)
#### Post date: [June 6, 2017, 10:06pm UTC](https://community.inventables.com/t/solved-x-carve-stopped-working-after-easel-upgrade/38538/22 "2017-06-06T22:06:37Z")
</div>
Ok, that’s most likely the problem.
Let’s get things back to normal.
Down load the .hex file in the link that Phil gave you and use the following procedure to upload that version of grbl into the Arduino. It’s a derivative of the Inventables fork and is very stable.
After you get that loaded in, go through Easel machine setup to get things configured the way you want them.
> [@Xloader - instructions](https://community.inventables.com/t/xloader-instructions/31039):
> How to use Xloader to load a new version of grbl into the Arduino/X-controller. The left screenshot shows the window that Xloader displays when it starts. Enter the file path or browse to the .hex file that you would like to load into the Arduino/X-controller. Select the device type you are going to load into (Uno/ATmega328 for the Arduino/X-controller). Select the COM port where your Arduino/X-controller is attached. The baud rate should be 115200. Press the “Upload” button. When the .he…
_[View the full topic](https://community.inventables.com/t/solved-x-carve-stopped-working-after-easel-upgrade/38538)._
