As has been indicated in a number of threads on here, since the gshield is not seating properly, is it possible you have the incorrect header pins? ( I did)
Are they touching down on the housing preventing the gshield from seating?
Look closely at where ALL of the pins are soldered to the gshield. any unsolderd ones?
Intermittent contact will make you crazy and cause hair loss.
