# Need help with Machine settings
**URL:** <https://community.inventables.com/t/need-help-with-machine-settings/73226>\
**Category:** Uncategorized\
**Created:** [May 18, 2019, 4:52pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226 "2019-05-18T16:52:55Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![EricKHolder](https://avatars.discourse-cdn.com/v4/letter/e/8e7dd6/32.png) [@EricKHolder](https://community.inventables.com/u/EricKHolder)\
**Post date:** [May 18, 2019, 4:52pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226/1 "2019-05-18T16:52:55Z")
</div>
Yesterday I done an upgrade with a Super Z axis belt drive and stiffeners and risers. Prior to that I was having some issues with my machine settings. Taking advice from several different people with different suggestions I fear I have messed up my settings. When I try to run a carve now I always set everything up in the bottom left corner of my piece the bit always goes to the top right corner and starts my carve. Can any of you share the proper recommended machine settings? Thanks to those who help.
**Author:** ![HaldorLonningdal](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/haldorlonningdal/32/72377_2.png) [@HaldorLonningdal](https://community.inventables.com/u/HaldorLonningdal)\
**Post date:** [May 18, 2019, 5:16pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226/2 "2019-05-18T17:16:09Z")
</div>
Please share your current GRBL parameter values and if possible an Easel file showing your design/setup.
**Post date:** [May 18, 2019, 8:34pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226/3 "2019-05-18T20:34:32Z")
</div>
Haldor,
Did you get the pics I sent you?
**Post date:** [May 18, 2019, 8:46pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226/4 "2019-05-18T20:46:37Z")
</div>
No, I haven’t seen anything.
**Author:** ![NeilFerreri1](https://yyz1.discourse-cdn.com/flex009/user_avatar/community.inventables.com/neilferreri1/32/84403_2.png) [@NeilFerreri1](https://community.inventables.com/u/NeilFerreri1)\
**Post date:** [May 18, 2019, 9:34pm UTC](https://community.inventables.com/t/need-help-with-machine-settings/73226/5 "2019-05-18T21:34:18Z")
</div>
@EricKHolder Probably better to use this thread instead of PM-ing us.
