I had the same issue. All that was needed was a little tiny tweak to boost the current going to the Y-axis. I found the information first in the following post and also looked up the specifics on gShield’s wiki. It did the trick for me, hopefully it does the same for you.
I would also say to make sure you re-step through the tuning video at the end of the assembly instructions as well, just to be sure you’ve covers all of the possibilities.
